I replaced the accessory belts (all 3, old style not serp) on a 93 Sentra with 352,000 miles. I cheated a bit by walking the belts on, but yes, after loosening the adjusters. what I mean is I turned the crank pulley back and forth to force the belts on so at some point it (engine) went backwards for a bit. I started it up after all was said and done only to be greeted by a disconcerting start up rattle which lasted a few seconds. also, under the valve cover it sounded like loose marbles banging around which lasted about a minute. All noises went away and it drives fine...not too worried about potential damage.
So I guess some hydraulic thing having something to do with the timing chain possibly drained oil and lost tension until op built up. Not sure if that makes sense but it's all I have. All original TC components.
