Well, lets think about this.
What are you pumping out when you turn the engine with the starter? You aren't doing anything to the oil in the pan. You are pumping out some of the oil which is downstream of the oil pump, in the places that oil most certainly needs to go, like the rod, main and cam bearings, and the rocker arms. You are also scraping the oil film off the cylinder walls.
Is there a load on the engine? No, but that isn't the issue, you had better believe there is a load IN the engine! Try cranking one over with a breaker bar while the plugs are in to see how much load there is! Better yet, grab the flywheel by hand and try to crank it! You are looking at, let's say, 150 PSI in the combustion chamber, which is multiplied at the bearings, because of being absorbed by a smaller area compared to the cylinder volume.
I can't believe that some people would even consider running the oil out of the very places it most needs to be. When you fire a brand new engine, you don't even THINK about it unless it is liberally slathered with oil and assembly lube, and the oil pump is primed.
[ April 15, 2004, 05:35 PM: Message edited by: TooManyWheels ]
