I purchased them from NAPA, from what the Napa guys say it works very well and they sell a ton of it.
It did a very good job of cleaning out the slimy scum that was building up on the inside if the coolant bottle, and I assume elswhere also, flushed out with distilled water and refilled with Motorcraft Gold GO5/Distilled water and poured the conditioner in also.
That conditioner had me thinking after it was poured in, what do you think it is ? Any compatibility issues with GO5 ?
Radiator Flush & Conditioner -
Enviro tek Radiator Flush & Conditioner Overheating still remains the single greatest cause of vehicle breakdowns worldwide. All cooling systems have a built-up of combustion acids. To eliminate corrosion of steel and aluminum you should flush your cooling system at least once a year. This product does not require neutralizing.
Enviro tek Radiator Conditioner will boost coolant levels to exceed ASTM D 1384 and 3306 requirements. Exceeds heavy duty spec ASTM D 4656, 5345 and 4985, Caterpillar EC I, Detroit Diesel and General Motors. Enviro tek is Nitrate, Phosphate, Borate, Silicate and Amino FREE! Add to existing coolant every 12 months or 20,000 miles (30,000 kms). Enviro tek meets all USA, European and Japanese vehicle requirements and is 100% Biodegradable. Also contains new carboxylate technology.
http://envirotekworld.com/HTML/PRODUCTSENVpage2.htm#radiatorflushconditioner
