Hello friends!
Since Jan 2011 my car is post-guarantee one. So I switched to less expencive oil and started tests. The reasons of the tests - to understand the possibility to use local lubricant and find out the right OCI. Unfortunatelly i did not take M1 0W-40 for the test. But I assume that previous OCI=9450 miles was too high because of significant decreasing of TBN after 60 miles on new oil (too high oxidation of M1). At the same time there was no significant TBN decreasing after 2nd OC.
Another point - wear is higher in winter period that is not news)))
Code:
Oil M1 0W40 LUKOIL Luxe Synth 5W-40 SM/CF ACEA A3/B4
n/a VOA* UOA UOA VOA* UOA UOA
Miles on oil 9450 0 60 5280 0 110 6122
Miles on unit 69393 69453 74673 74783 80795
Sample Date: n/a 10/27/10 01/11/11 05/10/11 01/07/11 05/27/11 09/12/11
Make up oil: 0 0 0,3 L 0 0.2 L
Aluminum 0 2 3 4
Chromium 0 1 0 0
Iron 3 30 9 18
Copper 2 10 2 10
Lead 0 0 0 1
Tin 0 0 0 0
Moly 5 9 3 3
Nickel 0 0 0 0
Manganese n/a 16 3 3
Titanium 0 0 0 0
Potassium 2 0 0 0
Boron 47 39 71 46
Silicon 12 9 14 14
Sodium 4 1 3 2
Calcium 2720 2432 2400 2760 2880 2897
Magnesium n/a 39 13 n/a 14 15
Phosphorus 1000 952 920 950 907 914
Zinc 1090 1194 1100 1000 1005 1023
cST Visc @ 100oC 13.9 13.82 14.6 13.6 13.1 13.1
Fuel 0.3% 0 1.2% 1.1%
TBN (D4739) 8.5 7.16 3.80 8.84 8.45 3.94
TBN (D2896) 9.9 10.21
* – Quality certificates from producer
Code:
Aluminum 0 2 3 4
Chromium 0 1 0 0
Iron 3 30 9 18
Copper 2 10 2 10
Lead 0 0 0 1
Tin 0 0 0 0
Moly 5 9 3 3
Nickel 0 0 0 0
Titanium 0 0 0 0
Potassium 2 0 0 0
Boron 47 39 71 46
Silicon 12 9 14 14
Sodium 4 1 3 2
