Hyundai Sonata Oil Filter Question
justin , tx
I'm doing an oil change on my friends Sonata Monday afternoon. But I've read different things about it's filter. Is it a spin on or cartridge type? It's a 2006 with a v6.
CA
It's a cartridge oil filter. Remove the engine cover and you'll see the canister. The dealership is the only place you can purchase an oil filter, currently. Around $10/filter.
CA
Quote:
Thanks guys , but to make things more confusing , Purolator has a part # and it's a spin on filter.
The 4-cyl uses a spin-on filter. I may be wrong, as Wix could've released an alternative filter by now.
Baltimore
Wix shows it as a 57061, which is a cartridge, not a spin-on. Media: Paper Height: 5.157 Outer Diameter: 2.893 Inner Diameter: 1.677 The factory filters are pretty decent. DongWoo, Inc., makes them for Hyundia, Kia, and GM Daewoo. It's a joint venture with Mann+Hummel of Germany, and the filters I've looked at appear to be Mann+Hummel designs.
blupupher
Site Donor 2021
Katy, Republic of Texas
Quote:
... DongWoo, Inc., makes them for Hyundia, Kia, and GM Daewoo. It's a joint venture with Mann+Hummel of Germany, and the filters I've looked at appear to be Mann+Hummel designs.
Is this all the Hyundai/ Kia oil filters or just the cartridge?
Vermont
Purchased six cartridge filters (Napa Gold) for my KIA Sedona, same engine, on-line for $4.38 ea. along with six filters for my other car. Saved about 4 bucks per filter.
87sammy
justin , tx
Got around to the oil change today. No suprises , real easy to do. The dealer was the only place that had the oil filter.If it was my car I would throw the engine cover away pain in the butt for no reason.
E. Texas
An older lady down the street just bought a 2007 3.3 V6 Sonata. I told her I would help with oil changes. Are you saying the oil filter is located at the top of the engine compartment? I have not checked yet but that is unusual I think. I've always changed filters from the bottom of the car/truck. Is there anything else I should know like crush washers (my Honda requires a new washer at the oil plug after each drain)?
87sammy
justin , tx
Yes , the filter is on top. It's a cartridge design. You change the media and 2 o-rings that comes with the kit. It's under the useless but pretty engine cover. Remove 2 bolts and 4 nuts , real easy to do. Then you will see cartridge on the right. I used a strap wrench to remove cover. You will see where the o-rings go , no guessing. Although the aftermarket has part numbers , at the time the dealer was the only place that had the filter kit. 8 bucks and change.
