hydraulic fluid looks like used motor oil.....
New York
We have an old ('59 I think) Hyster H60 forklift at work. Hydraulic fluid leaks like a sieve when under load, and looks like used motor oil. We're going to change it, but what do these things take? Will a normal (AW46) hydraulic fluid be ok? Not sure if it doubles as tranny fluid, in which case I guess a multi purpose tractor fluid would be the best bet. Tough to find information on these old machines. Thanks guys.
Most Hyster's use Tractor hydraulic/trans fluid in the trans and hydraulic, and when they have a separate compartment for the hydraulic oil it is AW46.
GL-5 85W-140 in the differential if it is separate.
When in doubt on old equipment, I use UTF. It'll work just fine as hydraulic fluid, and avoid clutch/brake chatter when necessary.
