Bill,
For certain type of drivers/driving sure hybrids may not work well. For instance, if you are aggressive during acceleration and breaking you won't get any benefits from electric modules because:
1) hard breaking uses the standard breaks and regeneration is not activated - batteries not charged
2) hard acceleration uses full gas engine power and prevents battery charging; moreover depleted batteries cannot assist
During a hilly ride an impatient driver will probably use mostly gas engine and as it is underpowered for your particular route then sure it may use more fuel than a similar size engine lacking electic components.
However 99% or drivers spend 99% of the time commuting on flat terrain, so these special cases are not important and can/should be ignored. You don't judge a machine based on marginal use cases! For those infrequent trips you can always borrow/rent Corolla or whatever machine may be more suitable.
NiMH batteries are environmentally friendly so disposal and replacement is fine. Although the pack has many cells, they are mass produced and not too expensive. AA NiMH lasts between 300-500 charge cycles. However, typical AA use is to discharge from 90% to about 10%. The Prius controllers keep them closer to the middle, something like the 40%-70% range (not really sure exactly what are the numbers), so they should last longer, 1000+ cycles. From there you can do some math to convert this into years of service.
Note that NiMH batteries don't die suddenly, just stop working one day. Instead, their performance slowly degrades and they hold less charge. Just like the old drill whose battery doesn't last as long as when it was new after several years. To make matters worse, you can have several completely dead, zero or negative volt cells and the pack will still work as the other cells still produce sufficient current. So one can think that the pack is still functioning when in fact it may be down to 50% or less of the nominal capacity. Therefore I would be skeptical of the claims that 200K+ cars are still using original packs.
