This past Saturday I bought a husqy 235e from a coworker for 5 bucks. Yes, 5 bucks simply because he said he needed a bigger one for the type of cutting he was doing on his land. It didn't have a bar or chain on it as he said he was going to replace them but decided he needed a bigger saw instead. He said the primer bulb was bad and so when I got it home after work I took the cover off and discovered the fuel line was spilt all the way down to the tank and the bulb itself was fine. So I'm gonna replace the line and buy a bar and chain and go from there. Well, a spark plug and air filter to boot as well. It had plenty of good oil inside so I'll leave that be. Oh and the motor still has compression too. My research shows that this saw was discontinued in 2008, but parts are still plentiful.
You guys have any experience with this particular saw? Issues you had i may need to look at on mine or keep in mind?
