Originally Posted By: AEHaas
From another thread:
"This sounds like what has been going on on the Subaru boards. Quite a few people are modifying their cars, and using energy conserving xW30's. Then they go to the drag strip (or drive hard on the highway) and wonder why they've spun a bearing"
Jason Heffner, of Heffner Performance here in Sarasota is world famous for his twin turbo modifications on performance cars as the Dodge Viper, Ford GT and the Lamborghini lineup amoungst others. Jobs run in the 50 to 60,000 dollar range if not more. He has his own Dyno set up. ...
People are always blaming the part failures on the oil. ...
People who do not know what they are doing blame the oil. ...
aehaas
I didn't only blame the oil, although a lot of people are. More of my quote from the other thread:
Quote:
Cooling, det and state of tune probably comes into play in those cases as well. Subaru allows xW40's and xW50's under severe conditions, although 5W30 is on the oil cap and that's what a lot of people follow.
Does Jason Heffner run his oil for 4-5,000 miles? I think I'm more impressed seeing real world results from modified turbo Subaru's running thin oil.
A Subaru tech has posted that he's seen spun bearings from 5W30 in a conservatively driven stock WRX. Hey, maybe you should get the new STI that comes out soon and do some testing of your own!
Although, the failures are more common on the early WRX's. Unfortunately, the people that had problems didn't do a UOA and most claimed failure at or before 1k miles with 3,000 mile OCI's.
Wouldn't an oil with a higher HTHS provide a better cushion and reduce the risk of bearing issues? Or even a better oil (more AW additives like RLI, RL) than the typical Energy Conserving oil?
-Dennis
