HT/HS value: specs and reality
Thanks for sharing the info!
Some things I found interesting:
-M1 0W-40 HT/HS tested out at 3.9, better than its rated spec of 3.6
-Valvoline Maxlife 10W-40 tested out at 4.2
-Castrol 10W-60 (BMW M3 oil) tested out at 5.8!
-Castrol SLX Longlife II is only part ("teil") synthetic???
[ June 11, 2004, 07:33 PM: Message edited by: quadrun1 ]
A great link.
Results. testers found that the 0w-30 and 0w-40 oils fared well despite a bit of sceptism going in.
castrol 10w-60 did best in all hard running related tests ( no surprise here).
The economy brand "Gut und Billig" (="Good and Cheap") fared decent expcet failed coldstarts tests
This is by far the cheapest oil in the test at approx 2 and half bucks (1 Euro=slightly more than 1$).
Also testers were disapointed that some of the teilsynetisch marked oils showed no blending in of PAO's but just group III a distinction that they also seem to make.
This was especially the case with the "Gut und Billig"
This is just an off-the cuff summary. But I'll gladly answrr specific questions later.
(Its Friday nite and I gotto cruise)
Fred...
quote:
But the European Maxlife is not the same oil as the North American Maxlife. To quote from an email reply I received from Valvoline Europe last November:
"To be able to be successfull in the European market with unique products such as MaxLife we've customized the formulation for Europe. We even had to use more synthetic base stocks to meet the more stringent requirements of ACEA in Europe. The unique additives that do give the unique benefits to MaxLife are used in both the American and European formulation."
I called the US Valvoline techs and was told the US Maxlife 10w40's HT/HS is >3.5
Why isnt the Castrol 1-W-60 marketed elsewhere in the world specially in hotter regions of the earth is beyond my compreshension.
A couple things loosely translated:
Shell Helix Ultra, which is optimized for reduced oil consumption, contains also mineral oils, because oil additives better dissolve better in those (than in synthetic oil).
Castrol SLX Longlife II was the only oil that was close to the critical HTHS limit of 2.9. However, this oil is meant to be used ONLY in specific VW engines with WIV (extended service interval).
Is Castrol SLX Longlife II what we call German Castrol?
quote:
Originally posted by nortones2:
I was reading an article which explained that even fully-synthetic oils contain 10% to 20% base (presumably cheap Group I mineral oil), as the carrier fluid for additives. See http://www.bardahl.ca/faq.html
I'm not sure about other refiners, but I understand that Mobil moved away from using dino additive carrier oils years ago.
quote:
And they felt this was acceptable due to its LL spec mission.
Fred..
Primus, thanks for the link.
I believe the main difference between Noak volatility with certain oils that some don't use any or much less mineral oil as the carrier oil. This is why I believe some see excessive burn off with certain brands. Only certain grades though. Just a theory....I have no proof this is the case.
[ June 12, 2004, 11:17 AM: Message edited by: buster ]
Neat article. Finally the high school German kicked in.
As for the Bardahl link:
quote:
According to the API, to be 100% synthetic, an oil must contain 80 to 90% synthetic base stock. The 10% to 20% remaining is base oil used to mix the additives. And, according to the API, the semi-synthetic motor oils must have at least 10% synthetic basic oil. Bardahl XTC 5W-20, 5W-40 and XHD 5W-40 oils are made with 100% synthetic base stocks. They are a mixture of PAO (Group-IV), Group-III and Esters (Group-V).
As for add pack carrier oils, some of this is the stuff of legends. I find it unlikely that the "carrier" oils are 20% in a "Good" synthetic! Nor have I seen the API rules on synthetic. Anyone have these?
So Bardahl is a 3-way blend. Interesting.
I agree with their break in comments....
They did. Esters are used now in virtually all synthetic oils (even most Group III ones) to carry the additives.
[ June 12, 2004, 11:53 AM: Message edited by: G-Man II ]
Castrol SLX II was formulated for newest Audi/VW.
If somebody want to know GC data, look at Veedol Syntron 0W-30, it's Castrol Formula SLX cousin.
