Has that helped?Well, Honda's already had problems in cold climates with the 1.5L that led to a recall and reprogram. They were "making oil" to the point of stalling out and leaving people stranded.
It reduced it a bit, but didn't solve the problem, which I'm going to assume is a design issue with Honda's DI implementation. Many of its peers don't have this issue, or at least not to the same extent.Has that helped?
Has that helped?
Toyota new design combines both port injection and direct injection. These engines see less fuel dilution and also it will keep valves clean from carbon deposit. I am disappointed in Honda, they used to be number one in building engines, not anymore…It reduced it a bit, but didn't solve the problem, which I'm going to assume is a design issue with Honda's DI implementation. Many of its peers don't have this issue, or at least not to the same extent.
Toyota's system has been dual injection for many, MANY years, like 2008? Ford recently followed suit and has gone the same way. BMW doesn't seem to have dilution issues, despite not having a hybrid dual injection system.Toyota new design combines both port injection and direct injection. These engines see less fuel dilution and also it will keep valves clean from carbon deposit. I am disappointed in Honda, they used to be number one in building engines, not anymore…
Not 2008. Maybe 2015 or so for Camry. My es350 2012 lexus is old style, zero fuel dilution. I dont think I will be buying another Honda. Engine is not the only issue, the quality has been declining everywhereToyota's system has been dual injection for many, MANY years, like 2008? Ford recently followed suit and has gone the same way. BMW doesn't seem to have dilution issues, despite not having a hybrid dual injection system.
Good question, I have not seen anyone posting UOA for 2.0t with oil catch can, would be good to get some data.Will installing a catch can on the PCV system help to improved this oil dilution problem???
We had this discussion in another thread: https://bobistheoilguy.com/forums/t...l-engine-oil-tests.362880/page-6#post-6323756Not 2008. Maybe 2015 or so for Camry. My es350 2012 lexus is old style, zero fuel dilution. I dont think I will be buying another Honda. Engine is not the only issue, the quality has been declining everywhere
as the dual injection system first debut with the 2GR-FSE engine on the 2005 Lexus IS350
D-4S started with Lexus vehicles around 2007 or 2008, Toyota branded vehicles got it a bit later, 2012 apparently starting with the FR-S according to this article:Not 2008. Maybe 2015 or so for Camry. My es350 2012 lexus is old style, zero fuel dilution. I dont think I will be buying another Honda. Engine is not the only issue, the quality has been declining everywhere
My mostly highway driving ended up with 4-5% fuel dilution. I even tried doing oil change after 1hr drive. If you do short trips, I would imagine the number would be much higher than 5% which labs dont even measure. They say >5%,What's your driving habits? Is it consistent highway miles or frequent stop/go, start/stop, and idle?
It wasn't a recall, it was a service campaign for only cold climate vehicles. It was an update that reduced the likelihood of misfires under certain operating conditions. possibly due to a rich condition.Well, Honda's already had problems in cold climates with the 1.5L that led to a recall and reprogram. They were "making oil" to the point of stalling out and leaving people stranded.
This level of fuel dilution is normal for Honda 1.5/2.0T's and for numerous GDI engines across a variety of brands
These were my first UOAs. As others are posting, this engine has known dilution issues and mine is probably worse because it is tuned.No worries!
Had you done previous UOAs prior to the last two?
If so, what was the fuel dilution for those UOAs?
It is an expected level of dilution on these vehicles. If you look at other UOA's from GDI engines, a high level of fuel dilution is common.What does “normal” mean? Just because its high on all GDI cars does not make it normal. And somehow toyota figured out how to keep it dilution lower than Honda.
It was a recall in China:It wasn't a recall, it was a service campaign for only cold climate vehicles. It was an update that reduced the likelihood of misfires under certain operating conditions. possibly due to a rich condition.
While it's true that many DI designs dilute (and there are many that don't, or not to this level) Honda's issues appear to be more significant than other marques with the level of dilution actually resulting in stalling engines and disabled vehicles:This level of fuel dilution is normal for Honda 1.5/2.0T's and for numerous GDI engines across a variety of brands.
