- Messages
- 349
- Location
- Quebec, Canada
All this talk about oil is getting bor...err...I mean...interesting
Anyway, what are your suggestions/tips/advice on reducing oil consumption (ie. Using certain oils, additives that you think works, Driving Habits <- this is what I'm reffering to mostly, proper engine care, etc.). First off, does it have to be specific as to whether the vehicle is under mostly stop-and-go OR mostly highway conditions? If you think so, just make sure to mention it
Of course, this is provided that your engine is in pretty good shape (ie. no oil leaks). So far, here's what I've learned:
- Use heavier weight oil (ie. 5W40 instead of 5W30).
- avoid over-revving the engine (in my case, I normally stay around/shift at 3000RPM).
- Allow full warm-up before driving the car.
In regards to "full warm-up", does that mean I should wait until my Temp needle hits the middle of the gauge? So, explain yourselves, boys and girls (if there are any women here
Thanks,
Oz
![[Big Grin]](images/icons/grin.gif)
![[Smile]](images/icons/smile.gif)
