Because why take a chance of overfilling your vehicle, that can be just as harmfull as running low. I would definately never let it fall below the add mark.quote:
Originally posted by Patman:
Why wait until it's down a full quart? That means if you've got a 5 qt sump, you're running your engine with 20% less oil than it's capacity, and putting a lot more stress on the oil that's remaining. With my dipstick on my Firebird, it's got holes in it to help show the level better, and as soon as the top hole is empty, I add 100ml of oil to bring it back to the top again. I just can't bear the thought of waiting until my level was down a full quart, or even a half a quart, before topping it up.quote:
Originally posted by msparks:
Depending on the size of the engine, you should wait at least 5 minutes for the oil to drain into the pan to get a semi accurate reading. I never add oil unless it is down around the add mark which is almost a quart. Usually my oil level is between 1/2 and 3/4 full.
On the BMW, I never ran it to the full mark and it only held 4 quarts. Why because if you ran it up to the full, it would burn oil, or deposit the excess into the airbox.
As far as being anal, I would add 2-3 oz anytime the level in my BMW would fall below 1/2 way.
