- Messages
- 2,721
- Location
- MURICA
I actually used both, one on male and other one on female side. Thank you![]()
Everbilt 1/4 in. OD Compression Brass Cap Fitting-801129 - The Home Depot
Everbilt - 1/2 OD Compression Brass Cap Fitting - this product is as easy to use as it is versatile.www.homedepot.com
That fitting is likely not tapered thread, so you might want to put a few good turns of teflon tape or pipe dope on the threads .
