How to get a picture down the oil fill hole?
Western Washington
I tried to take some pictures tonight of and have no idea how people do it. I couldn't get the flash or the focus to go beyond the outside. Is everyone using an old school camera with manual focus and some sort of pin light flashlight?
Iowa
You could try the Macro(?) function. I figured that out when trying to take pics of some spark plugs.
Central Coast, Calif.
set your camera to macro, it is the setting that looks like a flower. shine a bright light down the hole while attempting to take the photo. try not to use the flash.
Pensacola & Vero Beach FL
Set the ISO pretty high (whatever high is for your camera, without injecting too much noise). Turn the flash off. If you use auto exposure, shoot a bracketed spread of exposures, or use spot metering.
Hill Country TX
I'd just crunch it up, like a ball of paper, and stuff it down there. Sorry for the smart [censored] in me coming out!!!!
ME
Try a piece of white paper in front of the flash. It will either diffuse it or let you bounce-aim it down the hole. If you have EV compensation, add +1 or +2, the outer valve cover will be washed out but the insides more visible.
CA
Wow, this is good info. I recently took pictures of the oil fill hole and out of about 15 of them, only 3 were worthy of posting. I'm going to retry soon.
I should also have added that you'll probably need to go manual on the focus. I use two cameras, a Canon G10 for most "casual" stuff (14.7 MP, but very small sensor which creates unacceptable noise above ~ISO-400), and a Canon XSi DSLR ("only" 12.1 MP, but much less noise) for the rest. If you have access to a DSLR, I'd use that, for two reasons. Usually, it's much easier to go manual on the focus, and second, when using higher ISO settings, you'll generally get less noise than you will from the smaller sensor cameras.
Saint Paul (ex-San Diego)
Camera and photo supply shops have a gray-scale standard for setting exposure. Without one of those, do not use white paper, try to find a light-to-medium gray sheet of paper and hold it in front of the lens to get the exposure time approximate. Then try various focal distances -- one of them should give a good result.
