Originally Posted by crainholio
I did the PTU fluid on our '05 Mariner a few years ago, and I'm 99% sure it had a drain plug on the opposite side of the case from the fill plug.
This post was a good reminder that it's overdue for another fluid change, that was over 90K miles ago. Will grab another bottle of Amsoil Severe Gear 75W-140 next weekend and get back under it.
Update: it has a small drain plug, it's on the same side of the case as the fill plug...both face the passenger side of the vehicle. Logbook shows I put in Mobil-1 75W-140 at 89K miles in 2011.
At 193K miles, 8 years and over 100K miles later, what came out was dark brown but still translucent as it poured out...no signs of contamination or overheating. The fluid level was below the fill plug when I removed it. Small amount of gray paste on the fill plug magnet (drain plug is tiny and has no magnet). Refilled from a partial quart bottle of RedLine 75W-140 that I had on the shelf, the unit only holds 12oz according to the manual.
As a sidenote, the rear diff was filled at the same 89K service and with same Mobil-1 gear lube. Still level at the fill plug and the sample I pulled with a syringe was also brown translucent. No drain plug, have to pull the cover...not gonna happen as the fluid is fine. These vehicles drive the front wheels and only add the rears during slippage, so the rear diff is having an easy life.
