I have been maintaining our 2010 Impala for the past 5 years and close to 100K. It's at around 130K miles now, is starting to show it's age and well... I'm sick of working on it.
Some more serious issues have all popped up the past year or so:
- The airbag light is on.
- The rear defrost stopped working.
- The trans is starting to not shift so great. I slapped a shift kit in it and flushed the fluid which helped a lot. Still slips sometimes on start so I know it's not healthy.
- The struts all need to be replaced soon. The passenger front sits lower that he driver side by about 3/4 inch.
- What I think is the sway bar end links in the rear are clunking around over bumps.
- Drivers side CV output seal is leaking trans fluid.
- Valve covers are weeping.
- Needs new tires this year and an alignment.
- Front doors are starting to rust on the bottom inside where the door skin folds over the frame.
- Needs a coolant flush, its on factory orange fill.
- Front end starting to feel loose and clunky over bumps. I'm sure tie rod ends and or ball joints need to be looked into. Starting to cause uneven tire wear.
The stuff above is on top of what I did this past year:
- Rotors and pads all around.
- Replaced Evap solenoid and purge solenoid.
- Tune up ( plugs, air filter, serp belt)
- Air blend door motor.
Question is, how do I convince my wife it's time to dump it while it's still worth a little money? I've tried to relay that it needs substantial work and isn't worth it, but the vehicle has sentimental value to her. It was the first car she ever purchased on her own and she just wants to keep throwing money at it. The list of things it needs compared to how little it's worth makes justifying fixing it very hard to me.
Should I make a list of all the things it needs and the cost VS putting that into a newer used vehicle? Stop maintaining it and drive it till it breaks then junk it? What's worked for you in the past?
