- Joined
- Dec 16, 2022
- Messages
- 831
I bought a pump to get the fluid in my diffs/transfer case. I did my front few days ago but it of course is a different fluid than what goes in the transfer case.
So I'm probably overthinking this, but I need to reuse the pump for the Tcase but it has to have the other oil removed first right? Empty the bottle, clean it out, clean the lines... do you guys just let it drip out for an hour and then fill the punp and pump a few shots of the new fluid out into a waste tank before pumping the fluid in the tcase, or do you use a cleaner to get it all out first etc etc.
