I understand the importance of letting an engine warm up before running it hard, but I've got a question about the extent to which this is necessary. My office is located literally alongside the freeway I use to go home from work. The onramp entrance is probably 300 feet from the parking lot exit. If I use that onramp, the car will generally have been running for about two minutes before I merge onto the freeway.
Most of the time, in an effort to let the car warm up more before accelerating to freeway speed, I drive a little out of my way to a different onramp. This other onramp is far enough away that my coolant is almost to operating temperature by the time I get there. This isn't too much trouble to go to if it's better for the engine, but I find myself wondering if it's actually necessary or if I'm being too paranoid.
I generally don't rev my car (an 07 civic, redline 6800 RPM) higher than 3500 or an occasional 4000 RPM to get up to speed unless there's some safety need like a semi that can't move over, and likewise I generally don't have to go WOT to merge. Is that really too hard to run an engine that hasn't fully warmed up yet?
