Digital gauge. Overnight cold. set to 32.0 & 30.0
I remember seeing 20/20 or something like that, stating 60%+ of the tires on the road are underinflated, and most drivers don't have a clue. Hence the uncle sam mandated on board tire pressure warning system.quote:
I put about 2 pounds over the recommended values and check tire pressure every month or so. Thats more than 99% drivers on the road do.
32 is most likely a cushy setting the car manufacturer expects the customer will enjoy. I'd go higher, unless you drive really lame or on really awful roads. Higher pressure improves handling (firmer, crisper steering), improves gas mileage, and does indeed make the tire run cooler. I'd say try how you like 36 psi. Between 32 and 36 psi you should feel a distinct difference. You may go higher, but you'll notice every minute crack and pebble on the road, which is a trade-off. You'll also reach a point where handling won't improve. 37-38 psi is probably the limit for your car and tire if the manufacturer calls for 32 psi.quote:
The placard of my car's doorframe states 32psi. The sidewall of the tire reads max pressure 44psi. I have been told by more than one "tire specialist" to put it at the maximum sidewall psi for cool running and less chance of blowout here in on the "molten" asphalt roadways in the Summer's.
