reading another thread made me wonder - how much group III or PAO (don't know which they use) is in Castrol Syntec Blend? I mean, the stuff is almost $3/qt - it must be mostly syn, right???
quote:
A minimum of 5% is required by oil manufacturing blenders.
Would you please provide the reference links for these statements?quote:
Every one uses varying amounts too.... even changing the amounts within multiple brands inside their own house... ie... Conoco Oil Co with Motorcraft, Kendall, Trop Artic.
Castrol Startup and Syntec contain proprietary special esters.quote:
Originally posted by sky jumper:
about blending your own - would adding Redline (or another ester based synthetic) be more beneficial than M1 - because the ester "clings" better to cold engine parts, reducing cold start wear?
Last I read in either Lubes&Greases or MachineryLube Magazine was that there was no official or enforced rule as to how much synthetic base must be used to market it as synthetic. And the article(s) talked more about the definition of synthetic and what oils actually are.quote:
