Originally Posted By: slammin240tic
I rarely fill up my tank with gas. My question is can i treat each gallon without having to put ten gallons every time? I was using half an oz per gallon. But now what i use translates into 4 oz per 12 gallons, is that a healthy amount?
The recommended dose of MMO is 4oz/10 gallons of gas, or a 320:1 ratio. The dose that you are using is OK. Some guys run it a little less some a little more, just be careful you can OD with it, and cause poor mpg and loss of power. HTH
