What you're trying to do is get it to take the generated heat and use it to evaporate the diesel.
For that cat food tin, maybe a minute of torch on the outside of the tin would get the fuel pretty hot then using the torch to ignite the vapor would probably make it self-sustaining. Careful. Once you're above that threshold you'll have quite a fire on your hands.
That's the secret of the smudge pot. Once it gets above critical, the only thing holding it back is choking the air.
