Ethanol has a natural octane that is lower than that of other additives such as Toluene, Xylene or MTBE. Ethanol also has a wide Ron/Mon spread, meaning its MON octane (under heavy load) is significantly lower than its RON octane (under normal cruise conditions).
So if you replace MTBE, Xylene or Toluene with ethanol and keep the blend ratios the same, you will end up with a lower octane fuel than you had before. On top of that, the actual octane under heavy load will be yet even lower due to ethaonol's wide Ron/Mon spread.
For comparison, here are some (R+M)/2 octane ratings for common additives:
ethanol: 101
MTBE: 118
Xylene: 116
Toluene: 114
Note that the other additives not only have higher octane, but not revealed in these numbers is that their Ron/Mon spread is narrower.
The bottom line is, most engines will make less power with ethanol gas and there is no point to running any octane higher than what the engine was designed for.
ethanol: 101
MTBE: 118
Xylene: 116
Toluene: 114
