How much ATF coming out after a drain
MA
The car is acura integra with 1.8L engine. Right now it has 6 oz of Auto-Rx in it. It is about reaching 1K. I am thinking of drain and refill method. How much fluid am I expecting to drain? Thanks, George
gerard
MA
I know, but I am afraid jiffy Lube will screw it up by putting the wrong fluid.
Western Washington
What is about to reach 1k? Engine mileage? Mileage on the ATF? Mileage on the ATF since you put in the arx? FWIW, it should take around 3 quarts. Buy more than you need, then just replace with the exact amount that came out. Good luck :)
gerard
MA
It is about 1K on auto-rx. The mileage is 121K and I believe it is on oem atf. So I will just buy 4 quarts and drain and refill after a week of driving or so. Thanks
Upstate NY
A cooler line drain you can do yourself is easier than you think assuming you have a rubber line connecting the cooler to the transmission. Doing a cooler line flush will get all the old ATF out with the crud that Auto-Rx loosened. That is what you really want. Drain the pan then immediately do a cooler line flush. You can look up on the Amsoil website to see how much total ATF your vehicle takes.
