I was curious. Some people have reported that minor automatic transmission issues get cleared up with fresh fluid. Does that normally happen right away or does it take a while?
Car is 95 Nissan Altima.
Whenever I first get on the throttle, from a dead stop, I have quite a bad vibration. It's primarily in my throttle pedal as a driver, but if you're a passenger you feel it as being in front of you and in the floor.
It does it pretty much every time you are coming from a dead stop unless you use no throttle at first from the stop and let the car get moving before gently pushing throttle.
However, if say there is a yield sign and you ALMOST come to a stop not fully, you can push throttle as hard as you want and it's smooth as can be. Only happens from dead stop.
I have changed lots on car. Engine mounts, struts/springs, both axles, control arms, etc. etc. All made the car drive beautifully but this vibration is awful.
I did an ATF change today, had not been done since about 40,000 miles ago. I put in Mobil 1 ATF again.
If it was going to help, would it have helped pretty much immediately?
Not sure what else to try. Many thanks for reading.
