quote:
Originally posted by molechaser:
If I'm reading my copy of API 1509 correctly, any oil is eligible to be "energy conserving" if it meets the prescribed criteria. For 0W-40 SL oil these are FEI1 relative to BC 0.9% min, FEI2 releative to BC, 0.6% min, and sum of FEI1 and FEI2 1.6% min. These are measured on the Sequence VIB test.
Only 0W-x, 5W-x, and 10W-x oils can display the starburst and only if they meet ILSAC GF-3 spec.
This is exactly right. The ILSAC sheet I've got lists specific fuel economy guidelines for 0W-20, 5W-20, 0W-30 & 5W-30. Everything else has a group spec meeting an avg efficiency improvement of 1.6%. It does not give any info regarding the reference oil.
In contrast, the ACEA sheet I've got
only lists fuel economy improvement requirements for the A1/B1 & A5/B5 ratings, which must equal at least 2.5%. It lists the test as CEC-L-54-T-96, & the 15W-40 reference oil as RL 191.
If an oil meets the generally-more-strict A3/B3 rating, then there's neither an implied nor required fuel economy benefit. This leaves a manufacturer to look for other ways to claim this benefit, & ILSAC is a convenient way to do this.
quote:
Originally posted by TooSlick:
Mobils own SAE papers showed that the 0w-40, "trisynthetic' formulation sheared down by 20% in the Sequence IIIE, standardized engine test. From what I've seen, the "Not-So-supersyn" isn't any better in this regard. ...
C'mon Ted, give it up. Mobil hasn't made TriSyn in how many years?? It's irrelevant data at this point. As far as SuperSyn goes, the UOA section on this site has shown that, in normally aspirated engines, it holds up equal or better to oils with narrower viscosity spreads.
