Originally Posted By: ZeeOSix
Originally Posted By: jk_636
Look at the chart again. Only 1 failure before 3k, and the majority occured in filters above 3k. We really dont known when or why these filters are failing conclusively. IF it was a manufacturing or quality issue, it would happen to all of them, not just some. Pure rubbish
These people make MILLIONS of filters at a time. For all we know it could have been a bad couple batches, and they now have it under control. I ran a Pureone 5k recently and found 0 tears and pleats that were straight and uniform. Kind of puts a damper on that theory!
No, it's not rubbish. If you were to catch up and read all the threads about the Purolator media tearing issue, you would see that the ones that keep tearing in the same place over and over again are all built the same way. That is wide pleat spacing at the seam AND wide pleat V-spread. So it IS a manufacturing issue. And Purolator could have also changed their media formula, or received a bad batch of media if they buy from a supplier.
LOL ... just because YOU ran one for 5K and there weren't any tears doesn't mean the problem is "under control" and all theories are now debunked. You do understand that not ALL will tear ... but the ones that are built as I described above have a good chance of tearing. It's not rocket science.
You should look at the data again. There are 23 filters that failed between 3K and 5K miles of use.
There is even one that failed at 483 miles - explain that one. And what makes you think this issue is only applicable to BITOG members who only cut open oil filters. Do only Purolators that tear somehow magically happen to get installed on those guy's vehicles? If you could cut open every Purolator used on the road, you would see that it would scale up to what we have seen reported here.
I admitted to the fact that 1 filter failed before 3k and the rest were 3-5. No one is arguing that issue. I have said it before in other threads, the only way this data is relevant is if we were to construct a chart showing positive and negative filter outcomes. Right now we only have one part of the equation. Billions of filters made, hundreds-thousands opened by members here in a years time, and you have a handful of failures. So how widespread is the problem? Is there even a problem anymore? And come on, Im not saying that the problem is fixed because of my one experience, I am saying that there have been many on here lately showing purolators that havent torn! Get used to it, they aren't as bad as so many on here make them out to be!
