How do these spark plugs look?
WI
Out of my Liberty. Think they have about 40-50k on them, sitting at 200k now. Came out super easy. NGK V power nickel (put the same in). Old ones came out with a .050" gap, new is .040".
[Linked Image]
[Linked Image]
They look nice, but would need closeups of each gap and insulator nose to really tell anything.
.010" gap erosion is sufficient to trigger a change, though. And having nice, sharp corners on the electrodes supposedly helps idle stability.
Which reminds me; my Camaro is due.
I don't like extended tip - but not as crazy as some fords
If theses are heat range 6, I might try a 7. I found the V power to run about 1/2 > 1 H.R. above factory plugs on anything I've run them in.
Any pinging or loss of full throttle power when working hard?
Originally Posted by HoosierJeeper
How about these pics?
No signs of fouling as far as I can tell. Looks like they wore well and did their job.
Originally Posted by Nick1994
Can you take the picture a little further away?
Again, any pinging? Look a tad too hot. like I stated before.
I'd try a standard DENSO variant. Solved many Subaru running issues where the NGK factory p/n just didn't work well.
