How Bad is This?
OH
So obviously there is a big problem in the motor with these levels, what do you guys think. VR1 20-50 in a small block chevy used at the track in 20-40 minute sessions over a weekend. Oil looked like gold paint when I drained it so I sent it in for testing. This sample came out of the oil filter, I cut it open with tin snips.
Twisted46
OH
I though it may have ate the cam but all the valves move as expected, that doesn't mean it didn't. That amount of iron really worries me.
USA
Do you run leaded fuel? If so that's likely where your lead is coming from. It would be better to have the sample from the pan vs the filter. Also something to note is if you can see the particles the ICP cannot. The instrument will only see particles in the <15 micron range from the spray chamber through the injector into the plasma. Is there a bronze or steel distributor gear? Are there valve guide seals? 1 piece? Are they tight to the ID of the springs? Have any of them moved? I don't think what you and the ICP are seeing is the same thing. David
I think I'll pick door #2. Your small black Chevy probably has lead in the main bearings and one or more of the them got chewed up. For instance, if they were Clevite 77 Trimetal bearings they might have had a steel shell with a copper-lead alloy and metal babbitt containing tin and other alloys. smile
North Carolina
Not sure what to think with the sample coming from inside the filter that you used snips on. Should have taken a sample from the pan as it drained. You have a ton of silicon in there, and potassium so i think there is coolant getting through the intake or head.
Upstate NY
+1 - but I still think you will be rebuilding the engine.
Twisted46
OH
Hey guys, this is a great forum! I know I should have pulled mid-stream but I started the drain and went in to other things. When i came back I saw the gold mine deposit on top of my pan. I Did drain the pan before I started but I use it to drain all my auto fluids so it would be contaminated at best. I poured some oil in a mason her and screened it through a coffee filter, it was bad news. I cut the filter with a pair of snips that i cleaned with Dawn then acetone.
Nope I run an unleaded 95 race blend. Steel dizzy gear, brand new set of fel pro umbrella valve seals that stopped the blue/black haze at startup I was getting.
By the way, tons of Bittoggers run $35 oil checks and get the usual results: "wear metals look good; next time extend your OCI to xxxx miles and report back " (for another $35 hit).This is one of the first oil analysis I've seen that might actually help you make a useful decision on your engine. Flame suit in and shield in place. smile
VA
I got your back gladiator
Twisted46
OH
Yeah it is clear there is bearing damage which is manageable. My biggest concern is the iron. I will certainly post pictures.
Atlanta
Originally Posted by Twisted46
...My biggest concern is the iron. ...
It should be, it is the crank. [Linked Image from rangerxlt.com] Prolly looks like that...
