Our dryer is 220v electric. There is a run from the main panel (40 amps of fusing), to a sub panel (two 30 amp glass tube fuses) to the dryer.
A few weeks ago one of the sub panel glass fuses popped. The dryer wouldn't turn on. I traced the problem to one popped fuse. The other day the dryer would work, not no heat. Service technician came out and his notes are below.
"Checked voltage at the outlet and at first didn't get proper voltage. Then I got enough voltage for the unit to run and heat. The voltage is high at 256v. Unit requires 120v on each leg, total of 240v. Too high of voltage can cause issues with the units electronics."
I wasn't home so this is what I have to work on.
Is this a issue with my electric supply company? or electrician?
Thoughts?
Thoughts?
