Originally Posted By: 440Magnum
95 degree day, truck driven for over an hour, city/highway combo driving. Idle oil pressure ~25 plus, but still pushing >70 at 2000 RPM and peaking over 80 at the (limited in neutral) 4000. Dodge Ram 1500 310-horse 4.7L SOHC v8, 19,000 miles.
Video link
In short, I wouldn't go thicker on this engine. PS- note that the dash oil pressure gauge is an idiot gauge- doesn't move a peg. Hence the dashtop gauge... ;-)
I hope you find this helpful:
(1) There are no hydrostatically lubricated parts in an engine; so, the oil pressure is not that critical in lubrication as long as you have sufficient pressure, and the manufacturers specify a wide range of acceptable oil pressure. In a hydrostatically lubricated system, oil pressure would be what prevents metal-to-metal contact.
(2) Bearings are hydrodynamically lubricated, which means that you will have bearing failure at one point if you run a too thin viscosity, even though your oil pressure is sky high.
Oil viscosity is what prevents metal-to-metal contact in a hydrodynamically lubricated system, not the oil pressure.
Therefore, going thinner than what the manufacturer recommends is quite risky, especially if you drive hard or do towing. I don't know what is recommended for your engine.
Perhaps if you drive gently -- gentle acceleration, gentle throttle, no towing, etc., resulting in light loads on the bearings -- a thinner viscosity is OK. Also, fuel economy benefits of thinner viscosity are most pronounced for gentle driving.
