Nothing at all wrong with that UOA.
1. UOA wasnt done by you.
2. The only way to correctly do a UOA is the oil must be up to FULL operating temperature when the sample is taken and sample should be taken about the middle of the drain. Roll of the dice for a dealer to do that.
3. Your engine is brand new and nothing at all wrong with that UOA.
4. I understand you are freaking out but assure you, there is absolutely nothing wrong with your UOA. Your engine was breaking in for those 10,000 miles.
4. I understand you are freaking out but assure you, there is absolutely nothing wrong with your UOA. Your engine was breaking in for those 10,000 miles. [/quote
There is no way a flash point of 260F and absolutely trashed viscosity suggests there's "absolutely nothing wrong" with this sample. There are questions about how the sample was taken, but, having embarked on this exercise, there's no way the OP can relax and assume all's well.
What overkill said but add this ...
1. Fuel in oil is common in DI engines, even more so in Mazda high compression engines and why taking the oil sample is even more important and done the correct way and that way is full operating temperature.
There is nothing wrong with this persons engine, even the odds are way, way, way in his favor, the odds that one of a EXTREME few UOAs done on this engine in here WHILE THE ENGINE IS BRAND NEW AND ITS A HIGH COMPRESSION DI ENGINE NO LESS, UOA sample taken by a oil change guy at a dealer no less and based on this, some in here think there is a concern?
Its almost laughable, unknown sampling procedure and conditions done by an oil change person at the dealer on a brand new high compression engine.
Im just trying to reassure the OP, he is fine. Plus he has a 100,000 mile warranty I believe, so I would suggest maybe he do 2 more UOAs, over the next 10,000 miles and take the samples himself and that is if only he is concerned.
I think that was the point many of us were making: the sampling technique adds uncertainty here but the fuel dilution seems abnormal, even for a new, TGDI engine. So some further sampling seems like a good idea, especially if it can be done by the OP under the right conditions. Don't know why this has to become so contentious...
