Originally Posted by Cujet
The Euro's are nuts with the extended drain intervals. Those engines are stupidly expensive and a little preventative maintenance is in order. Many of the cars serviced by BMW and Mercedes dealers, right on the schedule are chock a block full of sludge. They come on the market after a few years and the next owner gets to deal with it.
I am absolutely not a fan of extended drain intervals. It's well known that timing chains wear faster with extended drain intervals. Why risk expensive repairs if you plan to keep it. Interestingly, even if you don't plan to keep it, just how much have you saved by not changing the oil.
Folks, there is no magic inside engines. Today's engines are just engines. They are not full of new wear surfaces that can tolerate abuse. They have hardened camshafts, steel timing chains, iron or "Nikasil" bores, iron crankshafts, aluminum pistons, chrome faced rings, soft metal bearings and ferrous oil pump materials. Just like they've had for the last 40++ years. The difference are in the tuning, direct injection and variable cam timing. Turbo's still coke up, bearings still wear and timing chains are just as wear prone as 50 years ago.,
Anyone that says things are better today is incorrect. Today's oils contain even fewer anti wear additives.
TAKE CARE OF YOUR ENGINE. Choose a good quality synthetic oil of sufficient viscosity and change it frequently. There is no other way to remove contaminates from your engine. Period, end of story.
I am going to disagree here with one specific item: manufacturing tolerances on the engine. The uniformity from unit to unit is far better for the average engine, than 20-30 years ago. Source - lots of background in IT collecting manufacturing data (GPIB FTW ! )
