The Honda MM is more than just an oil life monitor. New Honda vehicles do not contain a schedule like other vehicles do or did. All maintenance items are contained in that MM system. By changing the oil earlier than the MM indicates, you may be missing other critical maintenance items that are required, but the computer system doesn't "know" because these maintenance items notify the owner at the same time oil life reaches 15% or less. You could get around this problem, though, if you do not reset your oil life monitor after each oil change.
While I respectfully understand some posters insistance on changing oil (FF or otherwise) within a prescribed mileage, it is not generally a good idea and in most cases, unwarranted. The engineers developed a MM system with the understanding that oil quality and refinement is far superior than it was even 10 years ago. The Honda MM triggers based on a combination of factors.
