Honda VTM-4 Fluid VOA
Savannah, GA
I sampled some virgin Honda VTM-4 fluid. I will be using this fluid in the VTM-4 system in my '05 Honda Pilot. Butler/CAT Labs Sampled 8/13/2006 PPM: copper - 0 iron - 1 chrome - 0 nickel - 0 titanium - 0 vanadium - 0 silver - 0 lead - 0 tin - 6 aluminum - 0 silicon - 2 sodium - 2 potassium - 0 moly - 0 boron - 364 barium - 0 calcium - 272 magnesium - 155 phosphorous - 286 antimony - 2 zinc - 314 SAE Visc. - 20 Visc. [email protected] - 7.6 Particle Count per 1ml: >5u - 372 >10u - 129 >15u - 60 >20u - 27 >25u - 16 >50u - 3 >75u - 1 >100u - 0 ferrous debris - 12 iso code - 16/13 particle volume - 1 antifreeze - negative fuel dilution - negative water - negative [ August 29, 2006, 10:29 AM: Message edited by: joee12 ]
RI
Looks like ATF. Why not just use their fancy ATF-z1? Is this for the X-case or the rearend? If its the transfer case fluid, I bet that it is heavily friction modified for ultra smooth AWD engagement/disengagement. Now we need Honda VOA's of the ATF, the dual pump fluid, the PSF and.......
CA
There are special clutches inside this system...so be careful about substituting. The CRV takes Dual-Pump fluid, not VTM-4 IIRC. And the SH-AWD system in the RL takes plain ATF-Z1.
joee12
Savannah, GA
This fluid is for the rear-end on the Pilot and Ridgeline. The VTM-4 system is like a part-time 4wd system that kicks in the rear-wheels if the front ones lose traction. Basically I will be putting ATF-Z1 in the tranny and VTM-4 fluid in the rear-end, Joe Mike, no substitutions on the rear-end, but I am thinking about Mola's SF Z1 fluid for the tranny, Joe
