dead horse... kick...kick...
A scattershot selection of UOAs taken from different engines, at different mileages, under different sampling conditions, different OCIs, different fuels, and without any measurable degree of statistical significance are just indicators at best.quote:
Originally posted by bottgers:I don't believe the verdict is still out on the 5W-20. There are plenty of UOA's in this site alone showing it's superior to 5W-30.
Guys: Don't waste your time looking for the dead horse Graemlin. Try instead finding that little left arrow button, you know, the one entitled "Back," and clicking on it. Instantly, you will spare yourself the misery of dead horse conversations. I don't know about your computer setup, but mine doesn't have a gun that comes out and points at me while a pop-up appears ordering me to enter a thread I'm not interested in looking at, does yours??? BTW, my question did put a new twist on this issue (Honda vs. Toyota), which did draw one good, specific response.quote:
Originally posted by MNgopher:
dead horse... kick...kick...Yep...I'm not going to get suckered into one of these again. (where's the Dead Horse Instant Graemlin)
The don't "suck." A 5w20 is naturally going to have a lower HT/HS than a 5w30 or 10w30. Every 5w20 sold meets the SAE HT/HS requirements for that grade.quote:
Originally posted by Schmoe:
IF the 5W-20's are so freakin' great, then why are their HTHS numbers suck when compared to almost anything heavier????
There is no such thing as a modern 5w20 made with Group I. If it meets Ford's spec, it's made with Group II/II+, and III. Period. End of story. If it doesn't meet the Ford spec, but is certified GF-3, then it has to be made with Group II and/or II+. There is simply no way to build a 5wXX oil that meets either or both of these specs using Group I alone, or even with some Group I in the mix. (10w30 is another matter, however.) [/QB][/QUOTE]quote:
Originally posted by G-Man II:
Well, I honestly wonder if this Citgo 5w20 actually meets the Ford spec based on that MSDS. If the 64742-54-7 is comprised of A LOT of Group III, then I could see it (the CAS # for Group II, II+, and III is the same). But if this is all Group II, then I have my doubts.quote:
Originally posted by Motorbike:
I hate to be the grim reaper here but group I albeit in a small amount can be used with group II and III to achieve the Ford - Honda spec.
But now you are introducing another variable beyond viscosity.quote:
already broken down in terms of viscosity beyond what the 5W-20 would break down to. This is because the base stocks used in 5W-20 are far superior to those used in the 5W-30's.quote:
et
But Redline measures HTHS differently, so it's not directly comparable to other HTHS numbers.quote:
Originally posted by TallPaul:
If I were going to use a 5w20 (and I have no plans ever to do that, but say I bumped my head really badly and decided to get 5w20), I would like the best. Look at Redline 5w20: HTHS is 3.3! Nice!
How does it differ from the way other oil companies rate HTHS? Redline rates it in terms of cSt at 150C using ASTM D4741.quote:
Correctomundo....sometimes I enter things similar to a situation as one might meet a supermodel at a door. I go gaga and open the door for her...she slaps me in the face for being a chavinist pig. We both walk away happy.quote:
