Should I do a valve lash adjustment on our 1998 CR-V w/ 95k?
Have no clue...but I think its a wise idea that you adjust them.quote:
Originally posted by glxpassat:
Wow, my 99 Odessey has 122k on it and I've never had the valves adjusted. It runs great, but what happens if you don't do it, does the valve hit the piston? How could it get more tight over time?
Actually, I'm a "supermoderator" which allows me to mod all the forums. The 900/9-3 are my home forums. Too bad I wrecked my 900 and now have a sludgy 9-5! Hence the increase in BITOG posts and the envy I seeth when looking at those Accord and RSX pics. That's ok, my other car is a CR-V.quote:
Originally posted by vad:
He moderates two forums over there.
And the majority of the moderators are... foreigners
Hmmm, Brian, it doesn't look too good for you, my friend.
I start wondering about your loyalty to this forum and the country.
Please convince me otherwise...
I've had my timing belt replaced on my 4 cylinder Accord twice now, and I had the valve lash done both times. If you do it that way, you only pay for one valve cover gasket, instead of two if you do them seperately. I have no idea if it's standard procedure though...quote:
Originally posted by Auto-Union:
Is it normal practice for a decent mechanic to do a VLA when doing a timing belt on the Honda 4 cyl? We got the vehicle with 85k and a fresh timing belt, supposedly the mechanic nagged the owner into an early service. Would it be normal to have done a VLA at the same time?
