Dear all BITOG Viewers,
I currently have an AP1 Honda S2000 with an AP2 trans. It's about that time of the year to change the oil in the differential and the transmission. I have heard varying degrees of what seems to be a "good" MTF / Diff fluid for the S2k, all ranging from OEM to Redline... Here has been my experiences...
Redline MTF: When the oil was cold, the gears would grind. Once heat built up, I had no complaints
Honda MTF: Works fine, but under hard use, the fluid feels like it breaks down, requiring more effort to shift. In the trans now
So my question is to those who know Hondas well...
A. What fluid should I use for the trans? It has to work well with carbon fiber syncros, since the AP2 trans has them...
B. What should I use for the differential?
I am almost certain I will stick to Honda MTF for the trans, but what about the diff?
Any suggestions...? ...
Bueller?
Bueller?
