car marque: Honda
car model: Civic SiR II
year of manufacture: 1990
chassis: E-EF9
engine: 1595cc B16A DOHC VTEC
transmission: 5 speed Manual Y1 with LSD
Manual Transmission Fluid
oil brand: Honda
oil model: MTF
oil grade:
oil classification:
container markings: printed part no. 00210-01NZ
top up: 0
lube capacity: 1.8 litres
sampled: 09.10.07
miles on oil: 3,377
miles on vehicle: 140,390
oil changed?: yes
metals (OL1052) mg/L
aluminium mg/L: 2 (31*)
antimony mg/L: barium mg/L: boron mg/L: 2
cadmium mg/L: chromium mg/L: calcium mg/L: 2302
copper mg/L: 1 (200*)
iron mg/L: 17 (101*)
lead mg/L: 1 (125*)
molybdenum mg/L: 1
nickel mg/L: phosphorus mg/L: 1019
silicon mg/L: 4 (30*)
silver mg/L: sodium mg/L: 4 (51*)
sulphur mg/L: 6361
tin mg/L: titanium mg/L: zinc mg/L: 1230
vanadium mg/L: FTIR Scan Ext. (ASTM E2412)
oxidation: 33.5
nitration: 3.06
viscosity @ 40 C (ASTM D445) mm2/s: 30.30
Particle Size Analysis (ASTM D6786)
4-6 um (c) cnts/100ml: 6345207
6-10 um (c) cnts/100ml: 390900 (Slightly evlevated abnormal value)
10-14 um (c) cnts/100ml: 21626 (Slightly elevated abnormal value)
14-21 um (c) cnts/100ml: 4080
21-38 um (c) cnts/100ml: 307
38-70 um (c) cnts/100ml: 0
retained solids ppm (ASTM D4898) ppm: 3520 (0.50*)
particle quality index (OL1028): 11
total acid number (ASTM D974) mgKOH/g: 2.20
(*) are caution values for engine.
Comments by Oil Check
Particle count is slightly elevated for 6-14 micron
Other results are satisfactory
Recommend new oil be sampled at manufacturers recommended intervals to assess condition and monitor wear.
For the past 30,407 miles I have been using Honda MTF in my SiR II's 5MT.
Changed previously at every 12,429 miles.
My SiR II is not just my daily driver, and restoration in progress.
But also used for club level motorsport events like Dual Sprints, Bent Sprints, Motorkhana, and Trackdays.
Since starting to enter my SiR II into local club motorsport events.
I have decided to increase the frequency of MTF Changes to every 3,107 miles.
As I am nursing a graunching third gear synchro.
Earlier this month I changed the engine oil, oil filter, and 5MT fluid.
And took used oil samples for both my first time, and the car's during my ownership.
The past 3,377 miles has included four Dual Sprint club motorsport events, a single day of Track Testing with sessions lasting fifteen laps.
Not to mention daily driving chores.
The used oil analysis was made by Oil Check
chassis: E-EF9
oil brand: Honda
oil model: MTF
oil grade:
oil classification:
top up: 0
sampled: 09.10.07
miles on oil: 3,377
oil changed?: yes
lead mg/L: 1 (125*)
molybdenum mg/L: 1
sulphur mg/L: 6361
oxidation: 33.5
nitration: 3.06
