Very minor question, just got the Aisin TKH-002 kit to do the TB, and was under the impression the hydraulic tensioner uses engine oil pressure in addition to the spring to add tension. Eyeballing the replacement, there doesn't appear to be a hole. Is it just filled with oil to dampen it and does not use engine oil at all? I'm sure it's the right part, I'm just curious.
