Recently bought a used pressure washer off a family friend. It's got a Honda GC160 engine. Couldn't get it to start, and I wound up having to replace the cam gear. Got it running good, starts up on the first pull now.
The oil that was in it was looking pretty bad, so I only ran the engine for 5 minutes and then changed the oil. This is how the old oil looked when it came out.
Got fresh oil in, ran for another 5 minutes...and it looks like this.
The oil smells a bit like gas, so I was thinking that gas was leaking into the oil. I was getting some gas into the air filter too. I pulled the carb off and checked the fuel need and float. It looks to be in good shape, and seals correctly when I tested it with some gas. I also used some extra fuel line to blow into it and it sealed fine. Everything was super clean in the carb, no varnish or gunk anywhere. Still haven't gotten it back together yet, but how else could I be getting gas into the oil? Or could this be caused by water in the oil?
