Towed 2000lbs in 100F heat for the last 1300MI on the oil (95% Highway driving with little traffic). First 1300MI of engine were short trips in the city.
I am not going to freak out over the copper, iron, and aluminum since the engine is breaking in. I plan on leaving the oil in until the OLM tells me to dump it (as per the manual). Will do another analysis then.
code:Honda Odyssey 3.5L V-6 Gasoline Vehicle miles: 2,666 Miles on oil : 2,666 Life of oil : 7 Weeks Lab: Blackstone This is the type of oil used for Honda Factory fills, loaded with an anti-wear compound called molybdenum- disulfide and reading lighit in viscosity from use. We didn’t find anything high enough in this sample to be considered a problem. The highlighted metals typically read high in new Honda engine samples and metals and silicon will drop in the next sample. The TBN was 2.7, still some active additive remaining in the oil. We consider a reading of 1.0 or lower to be too low. The next sample should look better. Actual Universal Average Aluminum 14 4 Chromium 1 1 Iron 20 13 Copper 81 34 Lead 1 1 Tin 0 0 Moly 345 72 Nickel 0 0 Manganese 0 1 Silver 0 0 Titanium 0 0 Potassium 9 1 Boron 190 49 Silicon 91 11 Sodium 14 11 Calcium 1717 2223 Magnesium 11 63 Phosph 654 692 Zinc 782 825 Barium 4 0 Sub Viscosity @ 210 = 50.6 Should be 53-62 Flashpoint = 395 Should be >355 Fuel % = <0.5 Should be <2.0 Antifreeze % = 0 Should be 0 Water = <0.0 Should be <0.1 Insolubles = 0.2 Should be <0.6
