This is the first OC/UOA on the Fit. I took it down to 10% on the Maintenance Minder. 15% came at 10,154mi. I know the high wear metals and silicon are due to the break-in, but any other interesting stuff here or comments? I replaced the oil with Mobil 1 0w-20 and a Wix filter.
Code:
OIL Honda Factory Fill 0w-20
MILES IN USE 11,348
MILES 11,348
SAMPLE TAKEN 9/13/12
ALUMINUM 11
CHROMIUM 0
IRON 29
COPPER 21
LEAD 0
TIN 0
MOLYBDENUM 680
NICKEL 1
MANGANESE 4
SILVER 0
TITANIUM 0
POTASSIUM 5
BORON 212
SILICON 53
SODIUM 16
CALCIUM 2097
MAGNESIUM 15
PHOSPHORUS 760
ZINC 858
BARIUM 6
SUS VIS 210ºF 48.7
cSt @ 212ºF 6.87
FLASHPOINT ºF 375
FUEL% 0.5
ANTIFREEZE% 0.0
WATER% 0.0
INSOLUBLES% 0.2
TBN 2.3
Blackstone comments: Thanks for the notes. High wear and silicon are common finds in new engines. The metal is from new parts wearing in and silicon is from factory sealers and sand-casted parts. It normally takes two or three oil changes to wash
that stuff out, but the engine should look like universal averages soon. Those show typical wear levels for this type of engine after about 5,700 miles on the oil. Fuel dilution of 0.5% is just from normal use and not harmful. The TBN was 2.3 showing some active additive left; less than 1.0 is low. Try 13,000 miles on the next oil.
Code:
MILES IN USE 11,348
MILES 11,348
ALUMINUM 11
CHROMIUM 0
IRON 29
COPPER 21
LEAD 0
TIN 0
MOLYBDENUM 680
NICKEL 1
MANGANESE 4
SILVER 0
TITANIUM 0
POTASSIUM 5
BORON 212
SILICON 53
SODIUM 16
CALCIUM 2097
MAGNESIUM 15
PHOSPHORUS 760
ZINC 858
BARIUM 6
SUS VIS 210ºF 48.7
cSt @ 212ºF 6.87
FLASHPOINT ºF 375
FUEL% 0.5
ANTIFREEZE% 0.0
WATER% 0.0
INSOLUBLES% 0.2
TBN 2.3
