Originally Posted By: grampi
I'm not questioning that what you posted is true, but from an engineering standpoint, putting ATF in a manual tranny makes no sense. ATF is used in auto trannies to make a mechanical fluid connection in the torque converter. This process doesn't take place in a manual tranny as the coupling takes place by clutch plates and spring pressure. The only fluid required in a manual tranny is for lubrication, and ATF is a terrible lubricant...
This isn't new: I recall my Shelby Charger (1985) used ATF, though my mother's Omni (1987) used 10W-30. My 1979 Skyhawk's 5-speed used ATF. Note that Chrysler called for Dexron in manual gearboxes as far back as 1972!
Also, some Meritor and Fuller class 8 gearboxes now use ATF.
