That's an interesting theory, and frankly, one I had not considered. Yes, oils do perform to some extent as hydraulic fluid. Most dedicated hyd fluid is like (or is) ATF, i.e. thin like a 20wt oil, which would support your theory. On the other hand, my Toyota V-6 is a DOHC design and its "VVT-i" variable valve timing function is entirely dependent upon oil pressure to actuate its mechanical components, and it seems to run fine on 5w-30 and 10w-30 (and one fill of 0w-30). Of course, I haven't tried a 5w-20 in it, so I really don't know if would work better with that grade. Since Toyota does not spec 5w-20, I'm not inclined to try that experiment for a good while yet.quote:
Originally posted by james1:
I have an engine that calls for 5W-20. I have been using this oil since I purchased the vehicle last July and I have enjoyed watching the debate. In looking at the manufacturers/engines requiring this oil it seems that there may be a common theme and that is OHC engines. My Ford 4.6L is a SOHC with hydraulic chain tensioning and valve lifters. With multiple functions required of the oil and the fact alot is going on in the top end of these engines, it may be that flow/pumpability has been elevated in importance. Sort of like the multiple functions transmission oil must perform. I believe most of Ford's lineup is OHC and same with Honda. I have seen the statement repeatedly that the oil appears to be great for engines calling for this oil. I would tend to agree and maybe expand it to some OHC engines from previous model years. I am certainly no engine expert, but that's my 2 cents.
[ April 21, 2004, 02:37 PM: Message edited by: ekpolk ]
