Engine Make: 1996 Honda (4518H Tractor)
Engine Model: GX640 OHC 2-cyl, 38.7CID, Liquid cooled
Fuel Type: Gasoline
Oil Type: Schaeffer S7K synth. blend 15W40
Hours On Oil: Approx. 60-70 hours
Total Engine Hours: Approximately 500
Make -Up Oil: 0 quarts
Air Filter: factory
Oil Filter: Castrol MaxPro #3593A
Oil Capacity: 2.5 quarts
Initial Remarks: This is the first sample of used oil taken from this 18hp, liquid-cooled tractor engine which I’m having tested. Oil was in use for a total of about 13 months. This is the first time I’ve used a combination gas/diesel oil in this engine. Prior fills have been synthetic (Mobil 1) and or a mixture of synthetic and a conventional oil. The machine sees typical lawn & garden duty: 2-3 hours of mowing each week from May to October with some additional hauling of yard waste and occasional other uses. Tractor operates in very sandy conditions necessitating cleaning of the air filter’s foam pre-cleaner 2-3 times per year. We experienced some drivability problems with the tractor this year causing me to replace the (original) fuel filter which appeared clogged with dirt & debris. Old gasoline (possibly moisture contaminated) may have also contributed to the engine’s stumbling, uneven performance.
Aluminum 3
Chromium 1
Iron 10
Copper 4
Lead 1
Tin 0
Molybdenum 101
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 11
Silicon 5
Sodium 4
Calcium 2601
Magnesium 76
Phosphorus 908
Zinc 1200
Barium 30
Sus Viscosity @ 210F: 370F (should be 370F or greater)
Fuel Percent: less than 1% (should be less than 1%)
Antifreeze: 0%
Water: 0%
Insolubles: less than 0.2% (should be less than 0.5%)
TBN 7.8
Fuel Type: Gasoline
Air Filter: factory
Aluminum 3
Chromium 1
Iron 10
Copper 4
Lead 1
Tin 0
Molybdenum 101
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 11
Silicon 5
Sodium 4
Calcium 2601
Magnesium 76
Phosphorus 908
Zinc 1200
Barium 30
Antifreeze: 0%
Water: 0%
TBN 7.8
