First, the numbers [via Blackstone]:
First numbers are Honda 0W-20 w/ 3oz VSOT, second are factory fill [from Suzuka] also 0W-20, third are univ. avg...
xxxxxx / 8313mi / 4046mi
Date / Jun 6, 06 / Mar 25, 06
Al / 3 / 8 / 6
Cr / 0 / 1 / 1
Fe / 10 / 20 / 11
Cu / 2 / 7 / 5
Pb / 0 / 0 / 1
Sn / 0 / 0 / 0
Moly /734/543/144
Ni / 0 / 0 / 0
Mn / 1 / 3 / 0
Ag / 0 / 0 / 0
Ti / 0 / 0 / 0
B / 89 /184 / 63
Si / 26 / 76/ 14
Na / 7 / 10 / 12
Ca /1651/1623/2519
Mg / 74 / 15 / 50
P / 671 / 620 / 789
Zn / 808 / 685 / 947
Ba / 1 / 6 / 0
Viscosity 50.6 / 47.6 / s/b 46-59
Flash 360 / 305 / s/b > 385
Fuel% 1.3 / 4 / s/b < 2.0
Antifreeze & Water - zero on both samples
Insolubles 0.3 / 0.3 / s/b < 0.6
TBN was 3.2 on the first sample, I didn't bother with the 2nd, given the similar mileage.
Bstone notes on this sample noted the fuel dilute, said it was from ring seating and should clear up.
On the first sample, they said the oil sheared down to about a -10 weight. I'd guess due to the fuel dilute, and I *may* not have warmed up the engine enough before taking the sample.
When I read the first report, I was really worried about the shear, and to a lesser extent about the 20ppm of iron, as I'd never seen anything close to that level on my V6 Accords. Those first 1000mi were in cold January temps, as well
But I was just as happy on the other end of the spectrum when I got this last report. At least I *think* I should be. And I'd like to thank all the BITOGers who suggested the VSOT in various posts.
Looking at the Moly, Phosphorus, and Zinc, along with these wear levels, can I say I've found my 'magic bullet', as someone else once suggested when they found a good application ? Or is it too early yet to say that ?
I've tended to use M1 in the past, but given these results, I'm tempted to keep with the Honda labeled stuff - it's priced similarly, and it would only help, if any warranty issues arise - doubt they would, however.
Do I need to worry about the cat. conv., with these levels of P and Zn ? I've read they were lowered in the SL formulations for this purpose, not sure about the SM spec ?
My driving - 80% suburban, 30-45mph, 20% interstate 55-65mph. Engine generally never sees above 2500rpm, and I get 50-65mpg driving efficiently - that's a main purpose of having this type of vehicle, after all.
I didn't 'cook' / mix the VSOT prior to putting it in the 2nd oil; however, I did so with what's in the sump now - M1 0W-20. Put 3oz of VSOT in a carrier of M1 in the microwave for 10-15sec at a time until it felt just slightly warm. Mixing tips going forward would be appreciated.
One thing I noticed on the initial start-up with the M1 - the valvetrain was noisy for the first 2-3 seconds. Didn't happen with the Honda oil. Only happened with the 1st start. Neither the owner's or service manuals suggest pre-filling the new filter; I'm guessing it might have alleviated the noise
Sump holds 3.4 qts w/ filter change - I run 0.5qt low, again to help mileage; this Honda, as is usual, uses zero oil between changes. I do check it every 1000mi or so, and the level is steady as a rock midway between the add / fill marks.
Filters used are OEM Honda. I will probably stick with them until end of warranty; they seem good enough for this application, given the results ? In time, I'll probably start using PureOne.
Intent is to keep this car for the long haul; I'm very pleased with it so far.
Suggestions appreciated. Thanks for reading
Al / 3 / 8 / 6
Cr / 0 / 1 / 1
Fe / 10 / 20 / 11
Cu / 2 / 7 / 5
Pb / 0 / 0 / 1
Sn / 0 / 0 / 0
Moly /734/543/144
Ni / 0 / 0 / 0
Mn / 1 / 3 / 0
Ag / 0 / 0 / 0
Ti / 0 / 0 / 0
B / 89 /184 / 63
Si / 26 / 76/ 14
Na / 7 / 10 / 12
Ca /1651/1623/2519
Mg / 74 / 15 / 50
P / 671 / 620 / 789
Ba / 1 / 6 / 0
