Gentlemen -
I would like some advice from the Group. I know that changing the oil regularly and doing all the preventative maintenance will keep my car running well for many years, but BITOG is all about the pursuit of the "best" oil selection.
Background:
I recently sold my 2004 Tahoe (211,000 miles - no issues) and purchased a 2007 Acura TSX (6 speed). There are huge differences in the vehicles that might need a new oil strategy. The Acura is made to rev higher (5k rpms are not uncommon when hitting an on-ramp) and it is a 4 cylinder. The Tahoe was a V-8 with tons of torgue at low rpms.
Side Note: Switching cars will save at least $2K/yr in gas at $2.75/gal. That is a lot of $$ savings over 4-5 years. This is the main reason for the switch.
I drive a lot for work (35k+/yr) and I want to use the Acura OLM. My first oil change was between 5-6k. I believe this will be typical. The OLM on the Tahoe would allow 10k OCIs, but I never took it that far.
I put Mobil Clean 5000 in the Acura at my last oil change because I had some left in the garage. I planned to do a shorter (3k) oci as a flush and then switch to something else. I purchased some PYB for the next change, but now I am leaning toward PP for a few OCIs just to give the engine a good cleaning. Then I may switch back to PYB.
Questions:
- Would the higher revs of this smaller 4 cylinder lead you to one oil vs. another?
- Does the strategy for using PP for a few OCIs to remove deposits seem sound?
- Would anyone ever use M1EP or Castrol Edge for an extended drain in one of these engines?
I searched the UOA section and could find no reference to these engines. Any advice would be appreciated!!
Background:
Questions:
