We are all perfectionists here. Nothing wrong with that. But this was taken from the BITOG home page from OIl analysis and Wear Check as to what is considered Normal to Abnormal. Little reality check...
quote:Rarely, if ever, do we ever see these kind of numbers, which is why engines can last long on even the cheapest dino oil.
Engine problems predicted with oil analysis. Silicon (Si) and Aluminum (Al) 10 to 30 ppm Iron (Fe) 100 to 200 ppm Chromium (CR) 10 to 30 ppm Copper (CU) 10 to 50 ppm Lead (Pb)* 40 to 100 ppm Lead (Pb)* 10 to 50 ppm Aluminum (Al) 10 to 30 ppm Tin 2 to 5 ppm
